Author Topic: replaced coil pack still not firing on cylinder 3  (Read 2687 times)
Offline jay070983
« on: 03 August 2010, 16:48 »
can anyone tell me wot else this could be? ive heard that the ignition amp is a common prob?? any info welcome
Offline northeast_gti-t
  • "1.8T AGU"
Re: replaced coil pack still not firing on cylinder 3
« Reply #1 on: 03 August 2010, 17:07 »
i take it that you have an AGU engine code ? would be worth getting it scanned for any fault codes on vag-com
2000 Mkiv GTi 1.8T AGU
Offline richw911
Offline jay070983
« Reply #3 on: 05 August 2010, 17:17 »
thanks for the info but my engine is an aum and there is no ignition amp due to being built in to coil pack, measured voltage across each coil pack and cylinder 3 is reading more than the others so im thinking it could be something todo with ecu   :cry: any ideas??
Offline mattkh
« Reply #4 on: 05 August 2010, 17:19 »
Hi
Change plug no 3.
Offline richw911
« Reply #5 on: 05 August 2010, 17:20 »
Wiring  :undecided:
http://www.golfgtiforum.co.uk/index.php?topic=120994.0
Offline Mr_Orange
« Reply #6 on: 05 August 2010, 18:46 »
Wiring  :undecided:
I'll do it for £150 if you pay my travel expenses!   :grin:
Build thread clicky
Offline richw911
« Reply #7 on: 05 August 2010, 19:04 »
Wiring  :undecided:
:grin:
As said check the spark plug/ replace first  :smiley:
« Last Edit: 05 August 2010, 22:23 by Rhyso »
Offline jay070983
« Reply #8 on: 25 August 2010, 15:10 »
already changed plugs and coil packs but i know its not them now through testing incoming voltage so does anyone know if there is anything between the coil pack and ecu or is it a direct link?? :sad:
