Author Topic: go lower  (Read 1555 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
go lower
« on: 03 August 2010, 00:45 »
right
my coilovers are as low as they will go at the front, but i want to go lower!
how can i?
people say about taking the helpers out, or bump stops. How do i do this?
thanks in advance :)
Offline Dmonday
Re: go lower
« Reply #1 on: 03 August 2010, 08:49 »
right
how can i?
I would recomend not taking bumpstops out and no helper springs, i ran mine without them and it was basicly running with no springs at all!
helpers you can either just take your front coilovers out and take the helpers out or just take an angle grinder to them if you're lazy :grin:
http://tuningevolution.com/eshop/catalog/images/GOLF%20II-III%200001.jpg
the thinner ones at the bottom are the helper springs - mine we're above though.. doesn't make a difference :smiley:
Dan
Offline Len
Re: go lower
« Reply #2 on: 03 August 2010, 08:52 »
You dont drive anywhere without speed humps then Toby?
www.sas.org.uk
www.the-ace.org.uk
Offline Dan_GTi8v
Re: go lower
« Reply #3 on: 03 August 2010, 08:54 »
or park in multistoreys :P
I've only lowered 40mm and its very close coming out of my works car park
Offline Len
Re: go lower
« Reply #4 on: 03 August 2010, 08:55 »
TBH if you try and lower it anymore you run a serious risk of damaging the sump!
www.sas.org.uk
www.the-ace.org.uk
Offline Adam
Re: go lower
« Reply #5 on: 03 August 2010, 09:06 »
If you are set on going lower you can get top mounts that raise the suspension up 10mm thus lowering the car 10mm. Venom them.
Down Hill From Here.
Offline Dan_GTi8v
Re: go lower
« Reply #6 on: 03 August 2010, 09:08 »
bye bye front splitter :P
Re: go lower
« Reply #7 on: 03 August 2010, 09:47 »
Goodbye sump.
Offline tobybrennan
Re: go lower
« Reply #8 on: 03 August 2010, 10:46 »
i only really want to go lower for shows, ie. Edition 38
not for everyday drivingg :)
cheers lads
Re: go lower
« Reply #9 on: 03 August 2010, 10:52 »
cheers lads
The problem is getting it back to the same height each time plus checking the camber / tracking.
