Author Topic: MK3 DASH  (Read 1911 times)
Offline retromk2craig
  • Mk2 GTI And Mk3 GTI
MK3 DASH
« on: 02 August 2010, 22:46 »
HOW HARD IS A MK3 OR MK4 DASH CONVERSION IN A MK2, I WOULD LIKE TO DO DASH AND CARNTER CONSOLE. ALSO WILL CORRADO FRONT SEATS AND REARS GO STRAIGHT IN, AT THE MOMENT I HAVE MK3 SEATS AND CUT AND RE WELDED THE LEGS TO GET THEM TO FIT.
MK2 8V        MK4 4 MOTION
Re: MK3 DASH
« Reply #1 on: 02 August 2010, 23:50 »
I believe both will go in with work
Not sure on the Corrado seats
Re: MK3 DASH
« Reply #2 on: 03 August 2010, 09:58 »
front corrado seats straight fit, rears need work. see the guide on matey-matey.
you can make any dash go in with enough effort, mk3 is slightly easier for you as all the wiring will plug straight into your fusebox if its a post 90 mk2 with hazard on column. mk4 needs wire splicing
Re: MK3 DASH
« Reply #3 on: 03 August 2010, 21:01 »
mine is a 1990 model, do all the bolf holes line up?
MK2 8V        MK4 4 MOTION
Re: MK3 DASH
« Reply #4 on: 03 August 2010, 21:02 »
has any1 on here done this?
MK2 8V        MK4 4 MOTION
Re: MK3 DASH
« Reply #5 on: 03 August 2010, 23:14 »
I believe you will need some mods / brackets.
Offline The Mighty Elvi
  • I'm better than you today.
Re: MK3 DASH
« Reply #6 on: 03 August 2010, 23:30 »
The Mk3 dash is commonly available in the MK3 golf.  If you want this dash then buy a MK3.
The MK2 dash is regarded as being of better quality.  People who see you with a MK3 dash in a MK2 will regard you as a cock.
However.  You are free you do as you please.  Individualism is the choice of the free world.  But you will still be seen as a cock.
Its your car and do with it what you please...
N.B.
Putting a MK3 dash into a MK2 golf is like putting Vanessa Felz into gold Lamé hotpants.
worthy of adulation for your mechanical skillz.
But ultimately, disdain for your aesthetic ability.
Its a MK2 Golf. Unanimously voted the best GTI.
Why B-a-s-t-e-r-d-i-s-e  it
« Last Edit: 03 August 2010, 23:34 by The Flying Elvi »
Offline danny_p
Re: MK3 DASH
« Reply #7 on: 04 August 2010, 00:41 »
dash swaps are for show cars that don't get driven.
every singel car i've drive where someone has donee a dash swap has been nasty,  they usualy squeek and rattel half the stuff dosent work and they often end up ffitting badly
all the VW's have gone bar 1.
VeeDubGTI16v
Re: MK3 DASH
« Reply #8 on: 04 August 2010, 07:52 »
the corrado dash looks at home in a mk2 and is a lot nicer than the mk3 and 4 dashes
