Author Topic: ABS ECU how to open??  (Read 755 times)
Offline 3000GT ant
« on: 02 August 2010, 21:40 »
Hi guys, i've another quick question  :rolleyes: We have checked all the abs sensors and they are fine (reading between 1-1.3Kohms) So we now assume its the abs ecu. How do you get inside to take a look. Dont think i'm some novice thats going to mess it up with solder blobs, i am actually an electronics engineer so before we take it to the ecu doctor i wouldnt mind a look? I have loosened all the clips but the lid wont come off any ideas?
cheers
Ant
Offline javalin
Re: ABS ECU how to open??
« Reply #1 on: 03 August 2010, 12:21 »
asking a stupid question, but have you checked the wiring between the ECU and the sensors first?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Edwin
« Reply #2 on: 03 August 2010, 16:53 »
Have you checked that the ABS rings are intact?
