Author Topic: forge blow off valve????  (Read 3520 times)
Offline craig1986
« on: 02 August 2010, 18:22 »
i just ordered a forge adjustable atmospheric blow off valve from awesome gti... anyone got any tips for fitting or has anyone had any problems??????????
 :drool:
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: forge blow off valve????
« Reply #1 on: 02 August 2010, 20:10 »
why? waste of money imho and could actually worsen the performance.
Offline craig1986
« Reply #2 on: 02 August 2010, 20:24 »
Cos I want one
Offline JulesS3
« Reply #3 on: 02 August 2010, 23:31 »
So you can sound like an Renault 5 turbo?
Offline craig1986
« Reply #4 on: 02 August 2010, 23:37 »
Yeah why not? They sound ok
Offline JulesS3
« Reply #5 on: 02 August 2010, 23:46 »
 :rolleyes:
Offline Jimp
« Reply #6 on: 03 August 2010, 12:13 »
The fitting is pretty straight forward. The only real problem that comes to mind is a loss in performance since the engine was designed to recirculate the air rather than blow it off. It might not be noticeable at first, but over time it will cause errors as the ecu sees less air coming in then it expected, leading to a loss in power. There's a more detailed explanation in the mk4 section, since their engines are designed for recirculating air too.
Not low enough mk5
Not on the road enough mk3
Offline craig1986
« Reply #7 on: 03 August 2010, 13:04 »
ok thanks for that mate
Offline Jimp
« Reply #8 on: 03 August 2010, 16:52 »
If you want to hear the sound of the recirculator more you can fit a panel filter or induction kit and an exhaust, it will be a lot more noticeable then.
Not low enough mk5
Offline Upperoilcan
« Reply #9 on: 04 August 2010, 18:42 »
Exactly,to put such a thing on a mk5 should be a crime ! :cry:
Still as long as it makes a noise though eh ?........ :sick:
Mk7 GTI in black,DSG,fully loaded.
