Author Topic: ET40 Alloys  (Read 3086 times)
Offline zdebx
ET40 Alloys
« on: 02 August 2010, 11:40 »
Got a quick questions reg the alloys.
Found a cheap set of alloys, but the offset is ET40...
Is that a bit too much? The car is lowered 40/20.
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Re: ET40 Alloys
« Reply #1 on: 02 August 2010, 11:59 »
No will be fine, just make sure they clear the shock.
« Last Edit: 02 August 2010, 12:23 by Wayne »
Re: ET40 Alloys
« Reply #2 on: 02 August 2010, 12:04 »
may be a little low depending on your suspension setup, width of wheel and the tyres fitted, but worst case cheapo universal 5 or 10mm spacer will probably sort it
Offline zdebx
Re: ET40 Alloys
« Reply #3 on: 02 August 2010, 12:24 »
The tyres are 195/50/15 and the alloys are 6.5J. The car is not too low (40/20) and at the moment running 16x7.5J Borbets ET20 on 195/45/16 tyres with no probs.
So I'm guessing the 15's should be ok.
Re: ET40 Alloys
« Reply #4 on: 02 August 2010, 12:38 »
I would say, arch clearance will not be the problem as they are further in, as long as they miss the shock you should be fine.
Re: ET40 Alloys
« Reply #5 on: 02 August 2010, 13:29 »
yeah should be fine, the higher the offset the further in they will sit. they'll look totally lost in your arches compared to the 16" ones you have on there now :)
Offline robz
Re: ET40 Alloys
« Reply #6 on: 02 August 2010, 15:59 »
as above!
what ya getting though, pics ;)
Offline Jimp
Re: ET40 Alloys
« Reply #7 on: 02 August 2010, 16:47 »
Stock wheels are et 40 aren't they? You should be fine  :cool:
Not low enough mk5
Not on the road enough mk3
Offline Ess_Three
Re: ET40 Alloys
« Reply #8 on: 02 August 2010, 16:53 »
Corrado Speedlines are 6.5"x15", ET38-42 and fit on very low cars with no issues, certainly on 195/50/15 tyres.
You'll be spot on.
..but gaining motorcycles.
Offline Jimp
Re: ET40 Alloys
« Reply #9 on: 02 August 2010, 17:12 »
You'll be spot on.
I forgot about Corrado offsets, I have Estorils on the Vento, ET 30-something, 195/50/15 tyres and no issues whatsoever.
Not low enough mk5
