Author Topic: dash light goin mad!  (Read 3760 times)
Offline peteisfishing
« on: 09 January 2005, 17:12 »
just about to get me ands on a MK1 CAB. but there are a few probs
1. when i turned on the headlight switch the oil warning light flashes and the bty light came on!!!( ignition turned off.)
2.there is a worn patch in the middle of the drivers seat. They are the seat with the leather trim and cloth middle, does any one know where and how much this would cost to get sorted. I am near salisbury.
3. tried the indicators and the dash light just stayed on, not flashing. indicators not on but all the bulbs are new.
i am new to this forum and a bit of a sprog when it comes to MK1's any help is much appreciated, thanks folks
Offline Dizzie
  • Make friends with your fast
Re: dash light goin mad!
« Reply #1 on: 09 January 2005, 17:22 »
the indicator problem is linked to the plug on the back of the hazard switch if I remember right. there were 2 separate connections on vixter's cab that caused that problem if they weren't connected.
the headlight problem sounds like a really dodge wiring job.
« Reply #2 on: 09 January 2005, 17:30 »
Cheers dizzie, just spoke to the bl;oke who had it and he said he had a problem with an alarm system that was in it, so he took it out!!!!!!
problems started from there. Does any one know if there is a wiring diagram online ??? :laugh:
Offline Dizzie
« Reply #3 on: 09 January 2005, 17:35 »
« Reply #4 on: 09 January 2005, 18:29 »
Thanx mate, hopefully i'll sort it!!!!!!!!! :undecided:
Offline mk1
« Reply #5 on: 10 January 2005, 21:24 »
Check the brown earth wire that goes on one of the bolts on the rear of the rocker cover.
Steve.
« Reply #6 on: 11 January 2005, 17:42 »
thanks MK1, will have a go at the weekend
Offline ManicGTI
« Reply #7 on: 17 January 2005, 23:28 »
Offline tall pete
« Reply #8 on: 01 April 2005, 15:14 »
Quote
You ever fix this? I got the same problem.
Peter.
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
« Reply #9 on: 01 April 2005, 15:22 »
Had the same probem when I bought my cab.
The circuit board on the back of the cluster was broken. Changed the cluster and all is well now.
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
