Author Topic: vr6 distributor  (Read 1155 times)
Offline seamud
vr6 distributor
« on: 31 July 2010, 23:25 »
anyone know wt theplug on bottom of vr6 distributor does
mine broke and got to connect 3 wires from distributor whichh are
 red black and green and on engine loom the colours are brown black
red white and yellow black
Re: vr6 distributor
« Reply #1 on: 02 August 2010, 10:05 »
it tells the ecu where the cams are, the car will run without it connected but not as well. its probably the same connector as you find on the 4 pot engine distributors, so id be down the scrappy with me snips.  chop one off and solder to your loom
Offline seamud
Re: vr6 distributor
« Reply #2 on: 02 August 2010, 18:21 »
cheers mate much appreciated
