Author Topic: 20v turbo , crankcase breather pipe to inlet manifold,  (Read 1560 times)
Offline brianpologti
just got a quick question , my agu daily has started losing or lost boost, so had a quick look and found a split pipe, its the one thats a t piece, the small pipe goes to inlet manifold via a valve, and the other two are part of the breather side, one works its way to rocker cover and tip the other to the crankcase.  Which I know you do away with this t piece/valve it you do the catch tank mod, which I should really my finger out and order the parts, but I was thinking do I really need it as vw want 25 quid for this bit, or can I block off the inlet manifold pipe, and link the two others across, and pull my finger out and other a catch tank. cheers
Offline Diamond Hell
  • Opinions я Us
Re: 20v turbo , crankcase breather pipe to inlet manifold,
« Reply #1 on: 30 July 2010, 13:31 »
It breathes to the inlet to release pressure in the crankcase.
Block it up and you'll blow seals.
Not the marine kind though.
« Reply #2 on: 30 July 2010, 13:42 »
ok cool , i have to buy the pipe,  :sad:
