Head towards throttle bodies with proper management and then you will make power, probably some serious power at that. For example the BMW M power range makes 100 bhp per litre, this is done using throttle bodies and a proper management set up.
With regards to is it common, doubt it very much. The reason for the Digifant 3.2 system the ABF uses is not only for reliability/performance purposes but also for emmisions. The system can control the emmisions whilst also running a CAT, something a car with carbs can't do. You would fail the MOT as the MK3 was built around the time that CATs were mandatory (1992 onwards)
Edit! ^^^ beat me to it!
