Author Topic: Water hose diameter  (Read 2277 times)
Offline tri
Water hose diameter
« on: 28 July 2010, 22:39 »
I have a split hose and need to replace it. The hose goes from the water pump (just above the bottole rad hose) to a metal pipe (leading to oil filter area) and is about 4inches long could someone tell me the diameter of it so i can pick up replacement unable to remove from car right now and want to pick new one up tomorrow.
Thanks Tri
Offline Naz
Re: Water hose diameter
« Reply #1 on: 08 November 2011, 22:57 »
i ve got same problem with my mk2. could you tell me how you solved it plz, as i can't seem to get hold of the pipe thanks :sad:
