Author Topic: Help Brake Calipers  (Read 1000 times)
Offline garyrachel
Help Brake Calipers
« on: 28 July 2010, 19:54 »
Hi im new to the forum and just wonder if any of you guys will so here goes...
ive got a golf mk3 1.8 se... the front calipers/lucus have seized upand cant see the number on what i need and wondering if you know if a polo gti brake calipers lucus 54 would fit my car as ive seen some on ebay thought id ask you chaps as you like messing about wi cars etc or what brake calipers would fit the brake disc at moment are 256mm / 20mm thickness please help if you could.. Thanx Rachel
Offline garyrachel
Re: Help Brake Calipers
« Reply #1 on: 28 July 2010, 23:07 »
COME ON GUYS SOMEONE HAS GOT TO KNOW AND HELP ME OUT PLEASEEEE :wink:
« Reply #2 on: 28 July 2010, 23:10 »
I think Polo GTI is smaller brakes so they will not fit.
Offline garyrachel
« Reply #3 on: 28 July 2010, 23:31 »
So what other cars could i get them off..
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 28 July 2010, 23:34 »
Are you sure there 20mm wide as vented are 22mm at 256mm. My old 1.8 driver had 256x14mm solid's and were same calipers as mk2 gti
Offline garyrachel
« Reply #5 on: 28 July 2010, 23:39 »
yes im 100% sure that the disc are 256mm and 20mm vented..
  • Back in a Mk3...
« Reply #6 on: 28 July 2010, 23:47 »
if they are vented then late mk2 gti calipers should fit and them polo one's wont (different hose fixing!). I know some 2.0 non gti golf's and 1.9tdi's used vented 256mm brakes and searching for them would be best direct fitment bet
« Reply #7 on: 29 July 2010, 09:17 »
wayne 256mm vented discs are 20mm thick, its the 280s that are 22mm :)
yeah as above, if you have vented front discs then late MK2 16v calipers will fit. can also find em on mk3s obviously, and also corrados, Passats and some SEAT models. MK3 Cabrios are mmostly fitted with 256mm front brakes.  Polo 256mm calipers will bolt up as well, but the flexi pipe is different as said. you can get conversion pipes we got some for James' MK2 a couple years back.  You might even be able to use Polo hoses, or in fact later MK3 GTI 288 hoses may bolt straight up thinking about it
Offline garyrachel
« Reply #8 on: 29 July 2010, 11:11 »
Hi all...
would Like to say thankyou for your help and information...
Rachel
