Author Topic: golf gti 2.0 8v stutter problem  (Read 2236 times)
Offline Rayner_S
« on: 27 July 2010, 22:46 »
hi i have a mk3 golf gti 2.0 8v but it has a stutter problem pretty much everythign been chanced apart from the fuel pump far as i know also teh car feels like its being held back when u put your foot down in most gears revs go up but car just feels like some one is pulling it the otherway if that makes sence. has any1 else had the same problem and if so what could this be?? thanks
Re: golf gti 2.0 8v stutter problem
« Reply #1 on: 28 July 2010, 09:33 »
any faults on vag-com? what engine code is it, or if you dont know what year
Offline flash-derby
« Reply #2 on: 28 July 2010, 10:22 »
have you cleaned the t/b? did this on mine and it solved it.
does it stall?
if its got pistons or tits, either way its gonna be expensive
Offline robz
« Reply #3 on: 28 July 2010, 10:32 »
have a search mate, common problem with usually the same set of causes.
any stalling/cutting out?
Offline gophgti
« Reply #4 on: 28 July 2010, 11:33 »
mines just been in the garage for this problem turned out the maf sensor was fecked try unplugging it and take her 4 a spin c if it drives better?
Offline Rayner_S
« Reply #5 on: 28 July 2010, 18:41 »
thanks guys ill give all your suguestions a go and ill get back to ya see how i got on :)
Offline charlotte
« Reply #6 on: 29 July 2010, 00:54 »
ill try that 1 aswell ive just got a mark 3 golf gti 16v with the same problem.
Offline Rayner_S
« Reply #7 on: 29 July 2010, 22:03 »
thanks ever so much i think it was the maf censor if its the one just above the air filter :)either way iv disconnected it an its now working smooth as. just curious will it do any damage if i leave it disconnected for a while till i get a new one?
Offline gophgti
« Reply #8 on: 30 July 2010, 12:35 »
not realy mate no it will just run realy rich so it will just drink fuel lol
« Reply #9 on: 30 July 2010, 12:44 »
Can end up causing damage if left too long.
