Author Topic: K&N filter - worth fitting one?  (Read 1819 times)
Offline jonnygo
« on: 27 July 2010, 21:27 »
I had one in my XR2 many years ago - oval silvery thing
What are peoples opinions?
1. Will it boost performance by much?
2. Will I have to tell my insurance? (because if so, I will probably not buy one)  Insurance is group 17 I think
Golf GTI mk6 DSG in black - 18inch Monza shadows - leather interior - sat nav - f/r parking sensors - heated seats - well it was a showroom model!
Offline Duncreflex
Re: K&N filter - worth fitting one?
« Reply #1 on: 20 August 2010, 17:57 »
I wish somebody more knowledge than I would answer this thread, as was thinking of doing it myself.
My question would be; would it affect warranty?
Gti mark 6, Candy white, 18" monza shadows, ACC, cruise control.
Offline SteveP
« Reply #2 on: 20 August 2010, 19:48 »
Unless your going to be remapping the car adding a panel filter or intake will make zero difference.
The ECU with stock code just adapts around the additional airflow and in some cases (as I saw with mine while running in stock mode with the intake) will cause the EPC light to come one after a few hundred miles.
Offline PenguinGTI
« Reply #3 on: 20 August 2010, 20:08 »
That's what I found with mine. I installed a Carbonio style intake system. On the standard software it made no difference except for the warning light. With stage 1 software the warning light is not triggered but the car does not feel any slower with the standard air intake from VW.
I think it is really personal preference. I installed the Carbonio style because I thought it looked brilliant. But the increase in noise (sucking from the turbo) and the chatter lost their novelty after a while. The other thing that put me off was some studying the OEM system. The problem with the Carbonio style is that debris will get in to the casing. Once there it is can either go through the filter (not really possible) or remain in the casing until emptied. The OEM system has multiple exits for debris allowing the clean air to go into the intake. Kind of like a skimming effect.
Certainly the carbonio style brings more air into the intake but I reckon the air from the OEM intake is a bit cleaner.
As regards to the insurance you would be best telling them. (another reason I removed mine as Admiral don't take kindly to modifications  :sad:)
