Author Topic: Which head gasket?  (Read 1521 times)
Offline ramps
Which head gasket?
« on: 27 July 2010, 20:39 »
I have an 8v digi with a 2.0 bottom end on it, I don't know if i need the 1.8 or the 2.0 gasket set because i asume its the 1.8 head
thanks
Offline richard s
Re: Which head gasket?
« Reply #1 on: 27 July 2010, 21:02 »
when i did my engine a few years ago i used a 1.8 head gasket set for everything apart from the head gasket for that i used a 2.0 agg head gasket
Offline ramps
« Reply #2 on: 27 July 2010, 21:12 »
sweet, but whats a 2.0 agg gasket?
« Reply #3 on: 27 July 2010, 22:04 »
AGG is the engine code, you need a 2.0 head gasket due to the bigger bores.
Offline Alec
« Reply #4 on: 27 July 2010, 22:35 »
Wayne knows his stuff, on the receipts for the TSR 2.0 it has a 2litre headgasket listed on the invoice.
And he used to work there   :wink:
Offline richard s
« Reply #5 on: 28 July 2010, 17:55 »
agg was the engine code for the engine i had but i also think its a metal gasket and some of the other engine codes arent metal
Offline danny_p
« Reply #6 on: 29 July 2010, 01:33 »
same gasket as the ABF  think all of the 2ltr gaskets are the MLS type at least the later ones are.  they are much stronger gaskets.  the only downside is both faces have to be really clean to get a good seal.
MLS gaskets also require the head to be "flatter" than composite types so if fitting MLS it's highly recomended to skim the head
all the VW's have gone bar 1.
