Author Topic: lowering a v6 4motion  (Read 2607 times)
Offline V6_4MTN
« on: 07 January 2005, 19:59 »
hi all
       just got a 4 motion and want to lower it.any advice welcome as this is my first golf.
cheers ash
Offline gibby
Re: lowering a v6 4motion
« Reply #1 on: 10 January 2005, 11:03 »
Hi mate, opinions vary and people say different things, but if available for your car and money is no object then people will say go for coilovers, if you don't want coilovers then the best setup that most people suggest is Koni shocks with Eibach springs. Hope this helps.  :smiley:
......now officially dubless.
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 10 January 2005, 11:18 »
Alot depends on how much you want to lower it and what kinda ride you're looking for after.
If you wanna lower it and fit different wheels purely for cosmetics then that can be dealt with in a different way to if you want a lower centre of gravity and a stiffer, sharper ride.
Another thing to bear in mind is who will fit it for you?
If you're looking for cosmetics / wheels the final ride height is ultimately what you want to fine tune - I'd recommend ride  height adjustable coil overs so you can fine tune the height to avoid scrubbing etc but give you some level of flexibility.
If it's more to improve the handling the ride height isn't as important and you can get damper adjustable coil overs, again giving you control over how firm the ride is. Or just a plain damper adjustable kit ...
Alot of these fixed kits you can buy have such varying results - it might be to soft or not low enough for your taste - and you'll not know till you've spent the time and money fitting it!
You could go as far as buying a kit that can adjust both - but they're serious money for anything worth having.
Hope this helps ....
(As for the phrase 'coilover' it just mean that the coil or spring is set above the shock - when people refer to coil overs what they actually mean is ride height adjustable coil overs, as this arrangement has to be used to give the adjustment. If you bought a plain and simple coilover setup you wouldn't automatically set this height adjustment)
Sorry to be pedantic Gibby - just thought I'd set you straight  :wink:
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline gibby
« Reply #3 on: 10 January 2005, 11:40 »
No worries Mr H. No one had answered this question for a couple of days so I thought I'd answer it with the answers I got when asking the same question about mine.  :smiley: It forced someone to give the man a decent answer though  :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 10 January 2005, 12:23 »
I'd have answered, but I'm still in "lazy Christmas" mode :grin:
It's worthwhile upgrading the 4motion's ARB's to those from the R32, stiffens it up nicely at a very reasonable price :cool:
Offline V6_4MTN
« Reply #5 on: 10 January 2005, 13:25 »
hi
  thanks for the replys,was starting to think that i wouldnt be getting any.main thing was the best place to get new springs etc and what works best with the golf.as my previous cars have always been jap gtir gto etc.so i know very little about the golf.
cheers ash
Offline gibby
« Reply #6 on: 10 January 2005, 13:40 »
Ash, you could look on the main site www.golfgti.co.uk and search through the links that are on there or just do some searches around the net, then decide what route you want to go and then get some prices off the net and even ask if the prices are reasonable, most people on here have bought bits an bobs and will say if you've found a good deal or not. I found this site the other day,  http://www.motorsportworld.co.uk if you go to "Tuning tips" then "suspension" it might give you a few ideas.  :smiley:
  • Valver Bad Boy
« Reply #7 on: 10 January 2005, 14:13 »
I got my SPAX kit of these guys - very well priced and good product knowledge.
Offline ...joe
« Reply #8 on: 10 January 2005, 19:38 »
i may be way off here but am i right that some mk4's need a drop link reposition thing to stop something rubbing on the anti roll bars? i think this is only if your going very low but may be worth considering!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 10 January 2005, 19:49 »
On the later 1.8T's yea, go more than about 35mm and the arb fouls the driveshafts, so you have to either fit some droplinks or get an aftermarket arb, different setup on the 4motions though.
