Author Topic: Supercharger........  (Read 4038 times)
Offline RyanMac
« on: 26 July 2010, 13:17 »
Right here goes.....
You may all laugh at this but after finding out today from my gorgeous wife that I have a new arrival coming in feb :smiley: :laugh:(and no its not a golf :sad:) )I am looking to keep my costs for tuning the golf down.
I am looking to retain the 1.6 8v gti engine I have but change the camshaft to a fast road/race cam or a g60 one(would this work) but I am unsure as to which one so does anyone have any recommendations?
I also plan on using the eaton m45 supercharger I bought ages ago but would I need to fit 2 head gaskets to lower compression while at the same time I'd prefer to retain the kjet injection system and only change the dizzy ignition system to a megajolt ignition system....(along with some progressively fed nitrous later on)
I have a 2l 8v engine sitting but ultimately want to change that for a 1.8 16v engine with bike carbs etc but for the now I am having to stick with this engine and I have everything for it sitting around.
Has anyone any comments, will it work or is it totally wrong..... :smiley:
Offline Len
Re: Supercharger........
« Reply #1 on: 26 July 2010, 13:22 »
Good luck mate! yer gonna need it!
www.sas.org.uk
www.the-ace.org.uk
« Reply #2 on: 26 July 2010, 13:34 »
Not worth the hassle / work and expense for the little gains you will see.
K jet will not be anygood, you will need to go standalone managment.
Offline gibby
« Reply #3 on: 26 July 2010, 13:44 »
I stand to be corrected here, but I don't think you can turbo or super charge a kjet. :undecided: I don't recall ever seeing a kjet set up like that. kjet has no ECU either does it as it's mechanical injection.
......now officially dubless.
« Reply #4 on: 26 July 2010, 14:07 »
Broadspeed did it in the 80's with a pressured air flap, don't think it worked well to be honest.
Lack of safety if the mixture runs lean is the big issue.
Offline RyanMac
« Reply #5 on: 26 July 2010, 14:26 »
I am just going by what a friend done to his 1.8 8v kjet as he kept it all pretty standard but fitted a turbo. It all seemed to run fine for him but there may have been something else fitted that I cant remember.  I do remember him talking about a KSTAR or something though.....
« Reply #6 on: 26 July 2010, 15:13 »
Yes but is the work / expense worth it for a 1.6, the gains will be small
Offline LazyLunatic
  • MK3 20VT Project
« Reply #7 on: 26 July 2010, 15:16 »
didnt the lancia delta turbo engines run a similar setup to the k-jet?
« Reply #8 on: 26 July 2010, 15:21 »
Very early KE jet I believe or motronic
VeeDubGTI16v
« Reply #9 on: 26 July 2010, 15:29 »
volvo, saab and porsche all had kjet turbo engines, i suppose they just made the flap stiffer  :grin:
