Author Topic: Strange rushing noise mk 2 digifant  (Read 1485 times)
Offline E105
« on: 07 January 2005, 15:52 »
This is a bit of an odd one but when its under load and accelerating even lightly I get a rushing noise not quite a hiss but abit like that.  I dont think this is normal.  Almost like a very regular pre ignition noise.  Though I thought the knock sensor was supposed to sort out ignition timing.  I dont think its a vacuum leak but I do have a cold start problem, needs a good boot on the throttle then it starts and settles.
can the knock sensor be tested?
Any ideas on the noise?
Offline Overseer
Re: Strange rushing noise mk 2 digifant
« Reply #1 on: 07 January 2005, 16:53 »
sounds like a vacuum leak..
Offline E105
« Reply #2 on: 07 January 2005, 18:26 »
OK ill go through the induction system and check again :wink:
Veedubgt18v
« Reply #3 on: 08 January 2005, 22:10 »
check inbetween the pleats on the air hose to the throttle body as well these are often missed
« Reply #4 on: 12 January 2005, 13:21 »
Check the vacuum pipe behind the dash which feeds the MFA readout on the dash too.
Offline E105
« Reply #5 on: 03 February 2005, 19:41 »
OK solved this one now, was a combination of an overtight cambelt and slight blow from the exhaust, and no i didnt fit the cambelt.
Cheers for all your help.
 :wink:
