Author Topic: LIMP MODE? whats that all about? AHF TDI HELP  (Read 2756 times)
Offline CHRIS_MC
  • GHETTO GHOLFER
« on: 23 July 2010, 22:16 »
Ok, just pieced together my GT TDi AHF 110 (non PD)
and having driven my mk3 for the last 5 months, the mk4 seems slow
now, if when lining the engine up to fit the timing belt if fitted it in such a way that the cam is either advanced or retarded a tooth out, could this be causing it?......
i locked the fuel pump (mechanical) in place,lined the timing mark up to centre (TDC? i think) couldnt lock the cam, but had it lying at horizontal.  basically followed the haynes manual as best i could,
even cleaned the manifolds & egr pipe, basically everything that was coked up,
car seems lacking in serious minirals compared to the mk3 2.sl0w 8v
would adjusting the fuel pump pulley (which has 3 adjustable bolts) help at all?....... thought i should have had more beans that i do
it does feel torque'y in 2nd,3rd but getting it up to 88mph (time travelling speed) is a graft, is it possible even to adjust when the turbo kicks in? i dont have any VAGCOM stuff, or even know what that is , but it is a non PD engine so
any help or advice appreciated
« Last Edit: 23 July 2010, 22:19 by CHRIS_MC »
Offline Jay
  • balding fat cvnt
Re: LIMP MODE? whats that all about? AHF TDI HELP
« Reply #1 on: 25 July 2010, 09:08 »
Best place for non-PD help is probably going to be http://www.vwdiesel.net/forum/
