Author Topic: my mk2 abf track car  (Read 70132 times)
Offline Diamond Hell
  • Opinions я Us
Re: my new track sl@g
« Reply #40 on: 26 July 2010, 20:51 »
I'm confused.
What happens at the back?
Where are the seats from?  Rails like that are usually used on shelled bucket seats with side-mounts.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #41 on: 26 July 2010, 20:53 »
there out of a subaru the rears have flat bottoms on them if that makes sense so in theory i think can be bolted straight thru floor with plates underneath ?
  • Opinions я Us
« Reply #42 on: 26 July 2010, 20:57 »
 :huh:
That sounds nasty.
I was expecting you to say that you would be making a second bar to weld in at the back, so the seat is supported on a pair of rails.
Don't use seats that are designed for use with 3-point belts with harnesses - BAD idea.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #43 on: 26 July 2010, 21:01 »
i can make another bar not a prob if the seats were designed just for 3 point seat belt why would they have holes in the seats for a harness or is it just to make them look better  :undecided:
u can just about see the holes in there wierd
  • Opinions я Us
« Reply #44 on: 26 July 2010, 21:39 »
Bingo.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #45 on: 26 July 2010, 21:41 »
Bingo.
offs  :sad: well they will have to do for now in which case will my plan do for now ?
  • Opinions я Us
« Reply #46 on: 26 July 2010, 22:58 »
I don't know how it should have been mounted, angle-wise but it strikes me as it should be level and on rails, much like any seat.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #47 on: 27 July 2010, 08:00 »
yer looks that way so if i put rail at front lower enough and bolt the rear thru floor they will be sitting flat
  • Opinions я Us
« Reply #48 on: 27 July 2010, 09:16 »
If you're going to all this work why not make the seat rails suitable for proper buckets?
Strikes me as you're getting 90% of the way for a proper install then then falling at the last fence.
I *really* don't like this idea of bolting the seats down through the floor.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #49 on: 27 July 2010, 09:38 »
good point m8
so what il do is make another rail for rear and bolt rear of seat to that as well instead of goin thru floor that way when i decide to go for another set of seats there in place ready to go
also had a looky at the subaru seats and seams they have metal frame work al the way round the seat inside including were the holes are for the harnesses strange a
