Author Topic: Battery not charging  (Read 1017 times)
Offline janilic
« on: 21 July 2010, 17:21 »
How do. I've got a an issue where all of a sudden my car wouldn't start due to a flat battery. Changed the battery and started fine. next day the same thing happened. I've changed the alternator which has done bob all to sort the problem. the bat light doesn't come on on the dash.
Any ideas??
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Battery not charging
« Reply #1 on: 21 July 2010, 17:28 »
Did you charge the battery before fitting it and then leaving it?
For More Info Click To See;
Offline mk2bal
« Reply #2 on: 21 July 2010, 18:55 »
the light should come on the dash,then go out once its started. if it doesnt come on at all, and youve replaced the batt and alt then it must be a fault with the wiring to it all. check the blue wire hasnt come undone near the battery on the +terminal, and if thats fine check continuity of all the associated wires,the big one from batt to starter to alt, then the small blue signal wire from alt to batt connection, then to your clocks
Offline Agreeable Slick
  • Unit
« Reply #3 on: 21 July 2010, 19:18 »
Search function please bud.  :smiley:
