Author Topic: steering wheel?  (Read 1087 times)
Offline paul7278
  • boom boom problem solved!
steering wheel?
« on: 21 July 2010, 12:49 »
what vag nicer looking steering wheels fit a mk3 gti? seen a few on here but am unsure on what they come from.
Re: steering wheel?
« Reply #1 on: 21 July 2010, 12:58 »
Polo GTI
Re: steering wheel?
« Reply #2 on: 22 July 2010, 09:39 »
Corrado/Passat fit and for more modern looks 3.5 cabby, and mk4s with some modification. or to go the other way, MK1/2 Golf for the old skoolness.  the earlier wheels require the spline adaptor be removed which can be a pain sometimes
Offline gasketface
Re: steering wheel?
« Reply #3 on: 22 July 2010, 13:24 »
Be careful if fitting an aftermarket and buying a boss kit for it though,especially off ebay.Many sellers list them as fitting all mk2's and all mk3's.This is incorrect.Later mk3 has airbag and larger spline and an early boss kit wont fit the later car even if you take the adapter off.
Re: steering wheel?
« Reply #4 on: 22 July 2010, 14:33 »
later mk2s and all mk3s have the adaptor spline, the airbag bit you just remove if you have a MK2 late boss. the problem is when they list the early mk2 boss to fit late mk2 and mk3, in that case spline adaptor needs to be removed
Offline dontknow17
Re: steering wheel?
« Reply #5 on: 27 July 2010, 15:19 »
ive got a VW aftermarket steering wheel for sale with the hub...£20 if you want it. its chrome spoked (3 spokes) with black faux leather outside. unfortunatly has no airbag though!
Elliott
07787447835
Practice Makes Compound Fractures, then Perfect
