Author Topic: Gt tdi 130  (Read 3918 times)
Offline Gareth F
Gt tdi 130
« on: 21 July 2010, 10:29 »
Went to look at a Golf the other day but when i started it up the mpg read 29!
Now would this be due to every time its been started its been sat on idle or very short test runs?
Or is there likely to be something wrong? No smoke and quite a bit of poke lol.
No SmOkE nO pOkE....
Offline Rhyso
Re: Gt tdi 130
« Reply #1 on: 21 July 2010, 10:34 »
Did it have a 1 or 2 in the corner above it?
1 = short trip memory which resets 2 hours after you take the key out of the ignition
2 - long term memory which resets after 99 hours and 59 minutes
Offline Gareth F
Re: Gt tdi 130
« Reply #2 on: 21 July 2010, 19:50 »
Im afraid i didnt notice another number any where :(
Still is 29mpg ok if it was either of the numbers you mentioned about?
Offline jonesltd
  • MK7 R
Re: Gt tdi 130
« Reply #3 on: 21 July 2010, 20:04 »
I had those figures, changed my MAF and woohoo back to normal
If you cant find it......Grind it
Offline Adam
Re: Gt tdi 130
« Reply #4 on: 21 July 2010, 20:30 »
29mpg on what kind of run?
Thats very bad.
Down Hill From Here.
Offline Gareth F
Re: Gt tdi 130
« Reply #5 on: 21 July 2010, 21:29 »
It was on 29 mpg on idle when i started it up. Didnt have enough fuel to take it for a long blast, will do that when i get the funds sorted to buy one. Anyone else seen 29mpg on idle?
How much is a new maf and is there any way i can check its the maf?
Offline jonesltd
  • MK7 R
Re: Gt tdi 130
« Reply #6 on: 11 August 2010, 11:42 »
pop down terminus road and its a place opp jag garage and renault they will help (forgot the name)
Paid 90 odd but then returned my old one and ended up being around 60 mark
Offline gjroe78
Re: Gt tdi 130
« Reply #7 on: 11 August 2010, 14:59 »
I would say on idle and not going anywhere it's fairly normal  :undecided: takes a few minutes to sort itself out does it not ?
Offline Rhyso
Re: Gt tdi 130
« Reply #8 on: 11 August 2010, 15:03 »
Was that from the moment you turned the ignition on?
If so sounds to me like you're looking at the long term average - look in the top right of the little computer screen and if you see a 2 then that's your long term average MPG
Use the rocker switch on the end of the wiper stalk to cycle through the options  :nerd:
Offline Gareth F
Re: Gt tdi 130
« Reply #9 on: 11 August 2010, 18:38 »
Cheers for the info but bought the car anyway.
Mpg was 63 on the way home but after a few days ive realised my av mpg is 38 around my area as i sit in traffic so much  :angry:
With the money i save on fuel im doing little mods, currently painting a sharran badge black (only the vw bit)   :laugh:
