The garage
Unkown VAG-COM code!
Topic: Unkown VAG-COM code! (Read 3526 times)
1.6mk4GOLF16v
Here all the time
21 July 2010, 08:52 »
16708 - Knock Regulation -- Malfunction
P0324 - 35-10 - - - Intermittent
had this fault code come up after my management light came on, cant seem to find any info on it
anybody seen it before?
also where exactly would it be knocking?
Regards
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
sushi
Re: Unkown VAG-COM code!
22 July 2010, 10:22 »
Most likely Knock Sensor. Check the wiring to them as mine had corroded at the plug. Some engines have 1 some have 2 i think.
1.6mk4GOLF16v
Here all the time
31 July 2010, 12:43 »
where would i find the knock sensor?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
sushi
02 August 2010, 21:40 »
If you look just in behind your dipstick. You should see a grey connecting plug and a black connecting plug. Should have 3 little wires coming out (mine 2 had corroded off) The grey one goes to the crankshaft sensor which is hidden down behind the oil filter and the black plug (2 if you got 1.8 or 2.0?) goes down to the knock sensor.
Just check the wiring make sure there all ok if they are then you'll probably need to change the knock sensor. Quite difficult to get too easily and should be tightened to the correct torque....20 nm according to haynes.
The garage
