Author Topic: HELPP....VR6---new light has gone off!  (Read 1378 times)
Offline alirkhan
« on: 21 July 2010, 05:23 »
Hey guys, i cud use a little help here.....
Got my vr fixed and then suddenly this morning, this new light in the dash has gone on.....any ideas...?!!...tyre pressure?!!
Offline ian24driver
Re: HELPP....VR6---new light has gone off!
« Reply #1 on: 21 July 2010, 05:46 »
brake pads getting low or  maybe brake fluid level low.
Offline alirkhan
« Reply #2 on: 21 July 2010, 05:52 »
u sure mate?...cause i wud guess the handbrake light wud come on if nything is wrong with the brakes....worked like that in all the previous cars i had....hmmmm...where can i check?...i never got a manual or nything wen i bought the car...can someone pls confirm Ian`s hypothesis!.....
« Reply #3 on: 21 July 2010, 08:54 »
Brake pads or low fluid.
Offline alirkhan
« Reply #4 on: 21 July 2010, 10:52 »
aw man!!! so it is dangerous or sumthing?!!
Offline VR6_Wherry
« Reply #5 on: 21 July 2010, 12:55 »
I've got that on mine, it's the brake pad wear warning light!
Check the brake pads to see how much life is left, also give the brake fluid a check to make sure it's okay.
Offline AudiA8Quattro
« Reply #6 on: 21 July 2010, 13:04 »
As already stated, warning for front brake pads, so check them!
Nothing to do with handbrake or fluid.
Offline Adam
« Reply #7 on: 21 July 2010, 20:34 »
Get your pads changed ASAP. They go off when the pads are LOW and I mean low, I found out the hard way  :embarassed:
« Last Edit: 21 July 2010, 20:36 by Adam »
Down Hill From Here.
« Reply #8 on: 21 July 2010, 21:27 »
At least get them checked immediately.
Offline Khare
  • The bear that khares
« Reply #9 on: 22 July 2010, 09:38 »
kwick fit check brakes for free I THINK!
