Author Topic: Coolant Leak - Gasket or no Gasket?  (Read 797 times)
Offline Nova557
« on: 20 July 2010, 18:41 »
Hi all, hope someone can help.
I have got a coolant leak on my '96 Gti 8v, & have spotted that its weeping from where the housing for the coolant temp sensor mates up to the cylinderhead.
Any idea if theres a gasket in there that can be replaced to try & stop this ?
Offline Paul86S2
Re: Coolant Leak - Gasket or no Gasket?
« Reply #1 on: 20 July 2010, 20:30 »
Its not a gasket but a rubber o ring (except they are not shaped like an o)
Is the housing plastic? If so it is worth replacing the whole housing because they warp and or crack with heat and age. Thet are not too expensive from VW.
Paul
Offline dave_g
« Reply #2 on: 20 July 2010, 22:13 »
If it is the plastic housing, I recently changed mine on my 8v (cracked it putting a new sensor in! :sick:)
Cost about £14 robs from VW. One thing to note is that the new plastic housing has 2 holes in the top instead of the 1 where the coolant sensor goes, So if you order one, make sure to ask for another o ring and a plug. I didn't realise so have ended up putting my old sensor in the second hole!!!
Not sure if I saw the part on GSF cheaper too so you might wanna check there!  :smiley:
Easy to change, but does mean draining most of the coolant out the system so it doesn't p1ss all over your electrics  :grin:
Dave
