Author Topic: excessive play in bottom ball joint.  (Read 2320 times)
Offline moutains
Re: excessive play in bottom ball joint.
« Reply #10 on: 20 July 2010, 16:22 »
shop around most factors do the b/joint around £8
Offline mellow yellow
  • A Driffield Dubber!
« Reply #11 on: 20 July 2010, 16:46 »
cool thanks will do  :wink:
they still want 1 hours labour! £52.88  :laugh:
think i'll try tackle it myself with a bit of supervision.
Offline robz
« Reply #12 on: 20 July 2010, 16:53 »
147 is nothing to what ford dealer wanted - try 260 quid :D
Offline Horney
« Reply #13 on: 20 July 2010, 16:57 »
That's cheap for Ford. They charged my Gran £400 to change a rear wishbone bush.
Nick
Offline robz
« Reply #14 on: 20 July 2010, 17:01 »
:D robbers arent they!!
tbh mate, i had same problem 1 month agao, never done a wishbone before - not a trained mechanic, took an hour and a half tops just taking my time, and also i think it was on horneys advice, soaked the relevant bolts for 3 days in wd40 twice a day, bit excessive but certainly had no problems getting bolts out :D
Offline boneybradley
  • Back in a Mk3...
« Reply #15 on: 20 July 2010, 21:00 »
one thing i will add....mark the position of the old ball joint before removal and refit using these marks for alignment (otherwise you'll knock the camber out! and that's £50)
Offline robz
« Reply #16 on: 20 July 2010, 22:59 »
That aswell!!
I didn't bother, cos mine was out anyway so needed it tracking and camber sorting!
Offline AudiA8Quattro
« Reply #17 on: 21 July 2010, 00:04 »
I might be wrong here, but if i remember right they should be central in the slots.
