Author Topic: mk4 seats in mk3  (Read 2574 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
mk4 seats in mk3
« on: 20 July 2010, 14:59 »
will they fit does anyone know?
Offline Deano2711
  • 1992 VR6
Re: mk4 seats in mk3
« Reply #1 on: 20 July 2010, 16:05 »
Not as a straight swap Mate but you could fit any seats into your car mate. I put Scooby seats in mine but it takes some hard work and effort Mate.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 20 July 2010, 19:11 »
as above.....you need to weld mk3 subframes on!
Offline Dan_GTi8v
« Reply #3 on: 20 July 2010, 20:01 »
would it be possible to drill holes in seats and sub frames and bolt them together?
« Reply #4 on: 20 July 2010, 20:24 »
Welding is safer and stronger.
Offline tobybrennan
« Reply #5 on: 20 July 2010, 20:37 »
so literally take the frame off the bottum of your seats and weld it too your mk4 new seats?
sounds simple as my brother is a welder :D
Offline jonnypolish
  • t2871r needed :)
« Reply #6 on: 20 July 2010, 22:01 »
If your brothers a welder, the sky's the limit  :cool:
 MK2 VR y0!
Offline baby vr6
« Reply #7 on: 23 July 2010, 00:51 »
hey buddy , it is possible but it involves a lot of work!! cut the mk3 bracket of the floor pan. you need to fabricate a new bracket weld it to the floor you also need to trim the outside wheel down a good bit both on height and width. there s also a little wheel you need to trim off to allow you to slide the wheel down the runners. the rear suits are a bit more fiddly though, they invlove pullin the new material and foam off the seat and its a direct replacement for the whole seat(it fits nicely but a not perfect) doing this saves a lot of cuttin and makin new brackets  :wink: i done this a couple of weeks ago took me about 5 hours or so but that was me bein a bit lazy  :grin: mate you wont regret doin it so comfy and so much more support!!!
Cars are definitely female, they cost alot of money, need alot of attention, any holes in them get wider with age, and they need a good servicing every now and then lol
Offline Dan_GTi8v
« Reply #8 on: 23 July 2010, 07:09 »
Sounds a lot more technical than my old mk3 fiesta lol, just unbolt the subframes and bolt them onto whatever seats you want :P
Would it not be easier to take the old subframes off the mk3 seats and put them on the mk4 seats instead of putting the whole setup from the mk4 into the mk3?
Offline Deano2711
  • 1992 VR6
« Reply #9 on: 23 July 2010, 11:07 »
Loads easier this way....I bolted the Mark 3 runners to the Scooby seats then just slid them back into place. No need to start cutting the floor pan area. Loads easier !!!!!
