Author Topic: noob needs help,sorry guys lol  (Read 1149 times)
Offline maggots518
« on: 19 July 2010, 19:11 »
hi all,im new here as you can probs tell,i have a 96 gti colour concept and i need to lower the front by about 60mm,ive been told that mk2 shocks and springs will fit but im not convinced for some reason???any help apreciated.
Offline boneybradley
  • Back in a Mk3...
Re: noob needs help,sorry guys lol
« Reply #1 on: 19 July 2010, 19:39 »
they will fit but you need mk2/early mk3 spring cups. the biggest issue you may have is the mk3 lardy weight compared to the mk2 so spring rates will be off (basically mk2 -60mm front springs may lower it even more?)
« Reply #2 on: 19 July 2010, 21:21 »
Why are you only lowering the front, will handle crap
Offline AudiA8Quattro
« Reply #3 on: 19 July 2010, 21:23 »
Offline brett1975
« Reply #4 on: 19 July 2010, 21:29 »
just buy set of coilovers for £200 online, sorted.
Offline maggots518
« Reply #5 on: 19 July 2010, 21:40 »
got the rears ready to go on coz they were cheap so just need fronts but havin a hard time finding some one selling just the fronts,found quite a few second hand fronts for the mk2 but none so far for a mk3,if all else fails then coilovers it is,just trying to pennie pinch lol.
« Reply #6 on: 19 July 2010, 21:41 »
Mk2 will fit but unless you fitting a matched set up you will and can cause issues
