Author Topic: Fault code 00562 after fitting immo3 clocks  (Read 6834 times)
Offline Devilz
  • Cruisin is not a crime
« on: 18 July 2010, 19:33 »
Just fitted some immo3 clocks to a car that had immo2. Anyway, after finishing installing them it had a warning on turning the ignition saying "'Oil Sensor - Workshop", this message wasnt on the immo2 clocks.
Anyway vcds came up with the below fault code which would not clear. I proceeded with the mte and lit needles, corrected the mileage then reset the VDO. This cleared the message "'Oil Sensor - Workshop" and i thought thats good and didnt do another scan.
Address 17: Instruments      Labels:1J0-920-xx5-17.LBL
Part No:1J5 920 926 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01414
Shop #:WSC 00000
WVWZZZ1JZ2W617860     VWZ7Z0B4892532
1 Fault Found:
00562 -Sensor for Oil Level/Temperature (G266)
           30-10 - Open or Short to Plus - Intermittent
Offline Rhyso
Re: Fault code 00562 after fitting immo3 clocks
« Reply #1 on: 18 July 2010, 19:38 »
does the car have an oil level sensor?  If not then it will always come up as a code as its looking for something that isn't there
You can code that out anyway
Offline Devilz
« Reply #2 on: 18 July 2010, 20:04 »
its W reg, agu. how will I know if it got one or not  :undecided:
Offline Rhyso
« Reply #3 on: 19 July 2010, 08:01 »
Look at the sump - at the very bottom you'll see a plug (not the sump plug) if its there
Offline tshirt2k
  • Been there...Done that...
« Reply #4 on: 08 August 2010, 19:00 »
Doubt the car will have an oil sensor. You can get rid of i it i think by recoding the clocks to not use an oil sensor.
Mk3 ABF 16VT Megasquirt V3
