Author Topic: K jet seal replacement  (Read 1771 times)
Offline RyanMac
« on: 18 July 2010, 14:47 »
Hi all
I have a 1.6 8v gti and I need replacement seals for the fuel distribution block on top of the air filter housing. It is all the O ring seals and the mating gasket between the two distribution blocks.....
Does anyone know where I can get them from??
Re: K jet seal replacement
« Reply #1 on: 18 July 2010, 15:02 »
Bosch from memory or try a local o ring supplier but they need to be high pressure.
« Reply #2 on: 19 July 2010, 11:27 »
try vw for them, should be able to supply new copper washers etc. the one between the fuel metering head and air metering flap isnt special, so if you have a pack of generic orings these will do if can find one the right size.
the rest on there are copper washers, again if you can find em elsewhere the right size you should be ok.
vw do a repair kit for the pressure regulating valve as well, if required
