Author Topic: induction kit  (Read 2332 times)
Offline dubslug
induction kit
« on: 05 January 2005, 16:00 »
which one is best??
i got a 90 8v gti??
help plz
1992 pearl grey 8v
Offline davidhawkins_78
  • Valver Bad Boy
Re: induction kit
« Reply #1 on: 05 January 2005, 16:07 »
K&N Panel Filter matey with your resonator pipe removed ...
It's Cheaper - u still get a nice induction roar - nice bhp increase and improved throttle response - you retain the VW piping for cold starts and u avoid heat contamination.
Hope that helps  :smiley:
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline dubslug
Re: induction kit
« Reply #2 on: 05 January 2005, 16:21 »
wots a resonator pipe??
sorry first gti lol  :embarassed:
1992 pearl grey 8v
  • Valver Bad Boy
Re: induction kit
« Reply #3 on: 05 January 2005, 16:24 »
Well being a 1990 car I'm assuming you'll have a digifant - (hey better to be save than sorry!)
It's the pipe in the lower part of the airbox at the front that take the air from behind the headlight. It'll be obvious when you see it - it's there to reduce noise and we don't want that !!!
Just knock it out lightly with a small hammer ... add one filter panel and away we go !
Offline dubslug
Re: induction kit
« Reply #4 on: 05 January 2005, 16:29 »
think i may have already taken that out, like a blanking plate??
think mines a digifant, it hasnt got the metal fuel pipes on it??
1992 pearl grey 8v
  • Valver Bad Boy
Re: induction kit
« Reply #5 on: 05 January 2005, 16:33 »
Yup your's is a Digi ...
It's worth looking in to a chip to improve the throttle responce and make use of HIgh octane fuel with more agressive fuel and timing maps.
http://www.pitstopdevelopments.com/chip.htm
It's the same with the Digi 8v's as with the G60's
The resonator is inside the air box so I doubt you've removed it - I thinkyou're just talking about the plastic flap to tidy it all up - have a second look, it's like a funnel.
Offline dubslug
Re: induction kit
« Reply #6 on: 05 January 2005, 17:04 »
thanks i will have a look, ne for an induction kit and why??
1992 pearl grey 8v
Offline ...joe
Re: induction kit
« Reply #7 on: 05 January 2005, 17:55 »
i wouldn't go for an induction kit either. i've got a digifant like dave and have taken out the trumpet thing as well then used a k&n.
then the best thing to do is take the whole filter box out, underneath it you should see a sort of circle of metal that is tacked in place by three small welds, if there is a cylinder there instead you have a charcoal filter. knock this bit of metal out and plumb in some large ducting from this hole to the front bumper as a cold air feed. next chop a big hole in the bottom of your air box to match up with the ducting. so now you have a neat and tidy air box with a decent filter, with a factory looking cold air feed.
the thing about using induction kits is although they look good and sound quite nice (although my panel filter in modded air box is louder than when i had an induction kit) is that the suck in hot air from the engine. as we all know cold air is denser and your engine prefers it so by shielding the filter in the original air box you keep it away from all the nasty heat.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Judderi
Re: induction kit
« Reply #8 on: 06 January 2005, 08:51 »
Top tip gtijoe with the circle thing and some ducting!
VeeDubGTI16v
Re: induction kit
« Reply #9 on: 06 January 2005, 16:59 »
also, i closed up the warm air feed from the exhaust too, and i havent had any warming up problems this winter :smiley:
