Author Topic: People with ETKA  (Read 2169 times)
Offline RichGtiT
People with ETKA
« on: 16 July 2010, 11:58 »
Hey,
Ive noticed ive got a small leak in one of my coolant hoses, It's the one that attaches on to the back of the temp sender and it
goes into the bulkhead into the heater matrix i 'think'.  :undecided:
Could someone get hold of the part number/price please?
Rich
Offline Mr_Orange
Re: People with ETKA
« Reply #1 on: 16 July 2010, 14:17 »
Depends which engine you've got mate.  Assuming you have a 1.8T with the AUM engine, try part number 1J0121156AT
Does this look correct?
http://www.worldimpex.com/parts/genuine-part-heater-hose_76423.html
It's gunna be expensive if it is...  :sad:  Can it not be repaired?
Build thread clicky
Offline RichGtiT
« Reply #2 on: 16 July 2010, 14:27 »
sorry, my bad!! Im getting forgetful  :grin: It's an AGU mate.
Thanks for the help mate, yeah thats the part. Wasnt expecting it to be that much  :shocked: Ah well, gotta be done. Not sure if it can be repaired or not?? need to get a little bit closer to inspect it, not sure what i  would repair it wit though?
Cheers,
Rich
Offline RichGtiT
« Reply #3 on: 16 July 2010, 15:18 »
EDIT: just been looking at the forge coolant kit, i cant tell if it includes this pipe? Anyone got it and know?
Cheers,
Rich
« Last Edit: 16 July 2010, 15:24 by RichGtiT »
Offline Mr_Orange
« Reply #4 on: 16 July 2010, 15:58 »
Cheers,
Rich
On my ETKA it's the same part on both those engines, also AQA and ARZ types.  If that is deffo the hose you are needing?  Looks a be-atch to replace.
The Forge kit:
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260301&product=FMKC005
Appears to not include that one....  :undecided:
You sure its leaking from the hose and not the plastic temperature sensor housing like mine did?  Mine failed where it bolts to the cylinder head, the o-ring went on the back of it.
Get us a pic of the problem to have a look see.
Build thread clicky
Offline RichGtiT
« Reply #5 on: 16 July 2010, 16:21 »
Now that you mention it, it could be from there........
here is a pic for you to look at, excuse the quality its from my blackberry
Do you have a part number/price for this? was it easy enough to replace?
Cheers,
Rich
« Last Edit: 16 July 2010, 16:37 by RichGtiT »
Offline RichGtiT
« Reply #6 on: 16 July 2010, 16:32 »
sorry i dont think you can see the pic, im trying to find out how to make my flikr account viewable to public.
Rich
Offline Mr_Orange
« Reply #7 on: 16 July 2010, 16:35 »
If it is this, the part number is 06A121132AP, called "flange with sealing ring" and will be around £10.
Don't forget you need to replace coolant with the proper VW G12++ stuff  :wink:
Build thread clicky
Offline RichGtiT
« Reply #8 on: 16 July 2010, 16:39 »
brilliant, cheers. Ive got some G12 sat in the garage from when i changed the thermostat. How does the flange detach from the block?
Rich
Edit: if you right click the image above and get the URL it works  :undecided:
Offline Mr_Orange
« Reply #9 on: 16 July 2010, 16:47 »
Two bolts.  Looks like this:
http://www.urotuning.com/shop/cooling-hose-flange-p-949.html
If it is this and you end up doing it, it's not a difficult job, just takes a bit of time and the hose clamps can be a fiddle.  If you aint got the proper tool for them, I've found mole-grips set just right are good for holding the clamp open and moving it off the fitting.
When you take the old housing off, the aluminium head may be scored where the coolant has been leaking past, so clean this up properly with some wet&dry back to a nice flat surface.  Apply a small amount of grease to the o-ring prior to fitment to ensure good contact with the head.
If you haven't already, I'd suggest you also replace the coolant temp sensor (and o-ring) if you are taking it all off and draining the coolant.
Build thread clicky
