Author Topic: central locking,  (Read 2710 times)
Offline jon1676
central locking,
« on: 15 July 2010, 12:50 »
central locking key needs to re-programmed ,
but vw said passenger side 3 door came up with f221 implausible signal inermittent
ie  new lock is this right
thanks jon
Offline Rhyso
Re: central locking,
« Reply #1 on: 16 July 2010, 09:19 »
What happens when you lock the car?  Does the locking pin ping straight back up?  If so then you'll need a new door module
Can you lock the key from the remote fob?
Offline jon1676
« Reply #2 on: 16 July 2010, 10:00 »
hi rhyso, ( door golf)
        the keys need to be re-programed so opening on the key maunally ,turn once opens drivers door (normal) twice all doors and boot, but if you open boot or pass door alarm goes off, have to put key in ignition first its only that vw  said about the proplem/do the modules  cost a lot and hard to fit?
 thanks jon
Offline Rhyso
« Reply #3 on: 16 July 2010, 10:05 »
Do you only have one key fob?  Does the key start the car?  To me it sounds like it just needs re-synchronising which is a two minute job - don't let the dealers con you into a new key!
http://www.golfgtiforum.co.uk/index.php?topic=77197.0
Offline jon1676
« Reply #4 on: 16 July 2010, 10:08 »
one key ,getting a new as well, both will need re-synchronising hopefully thats it and your right about the dealers scaring a new owner
Offline Rhyso
« Reply #5 on: 16 July 2010, 10:12 »
Sadly you'll have to pay a bit more for thee new key as the immobiliser chip needs programming to the car.
Might be worth finding someone local to you with VAGCOM who would do it for a few beer tokens  :smiley:
