Author Topic: Aarrrrgggghhhhhhh Help plz  (Read 2495 times)
Offline indi
« on: 15 July 2010, 10:18 »
i bought a 99 golf gti turbo about a month ago knowing it had a few minor faults (door lock modules maf sensor and a few minor bits) anyway yesterday i orderd a new maf as the car was running very poor crap idle very poor consumption and a lot of backfiring from 3rd to 2nd gear  :sad:
After fitting the new maf i started the car all seemed very good smooth idle and i thought id cracked it, it wasnt until i went to drive it it started to die on me under acceleration at about 1500 revs but not all the time.
This morning car wouldnt fire up without me pressing the accelerator (never ever happened before) but when i got it going power was smooth and back to normal  but with the odd occasional gudder in power
Ive checked the hoses ive cleaned the 3 week old spark plugs so is the new maf foooked, i left the battery disconnected for the best part of 4 hours
HEEELLLPPPPP Plz :cry:
Offline AlanD
  • MK5 2.0T 16v
Re: Aarrrrgggghhhhhhh Help plz
« Reply #1 on: 15 July 2010, 10:20 »
Got to be the Coil packs.
Offline indi
« Reply #2 on: 15 July 2010, 10:22 »
Think it could be the plugs they were black has hell ? and only 3 weeks old?
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 15 July 2010, 10:23 »
When you say judder in power do you mean you will press the pedal but nothing happens and then have to give it a few stamps to get it back on power again?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 15 July 2010, 10:27 »
doubtful it's coilpacks on an AGU...
Could be a number of things; split hoses, ignition amp failing, throttle body needing cleaning...
If your plugs are black then it was overfuelling, have you cleaned them since the new MAF was fitted? This could be somewhere to start.
Do you have access to VAG COM to scan for faults?
Offline indi
« Reply #5 on: 15 July 2010, 10:33 »
yes its been overfuelling very bad 30 miles to a £10 of fuel and where talking with slippers on not boots  :wink:
i can get access to a vag com at the weekend and yes cleaned the plugs when i fitted the maf but for £16 i might just throw some new ones in
many thanks
Offline indi
« Reply #6 on: 15 July 2010, 10:35 »
when you start to accelerate it briefly gudders then its back as normal? but its not all the time
Offline richw911
« Reply #7 on: 15 July 2010, 18:17 »
+1 id guess at the ignition amp  :smiley:
Offline indi
« Reply #8 on: 15 July 2010, 19:38 »
Right just installed new plugs cleaned the throttle body and checked all hoses no leaks or splits
Still same :cry:
Ign amp failing will have to get it checked still strange how it's never  had a problem starting but now it's constant  :cry:
Offline richw911
« Reply #9 on: 15 July 2010, 19:43 »
