Author Topic: Help Please MK3 16valve Battery getting hot and leaking fluid after alternator  (Read 2341 times)
Offline Thebuzinezz
Hey if any can point out what i am missing this would be great. heres what i did and chcked
symptoms: battery light came on and would flick off if i rev the guts out it. car eventually stoped and a mate jumped started it, still no charge.
right!!! i changed the alternator to a RTX 12V 90AMP and new drive belt.
Now i am plagued by a host of other problems -
1. Battery heating up and spitting fluid
2. headlights keep turning out
3. Instrument pannel resets and has mindof its own basically.
I have checked the battery fuse 30A good and so are all the others and relays i assume are all good number 30 heats up alittle bit not sure (good/BAd)?
I am stuck i dont lnow what next to check... i even bought a new battery still same symptoms argh!!!!
Sounds like it is overcharging.
Offline bourbon
+1 overcharging
Peperami........ It's abit of an animal !!!
Offline raferackstraw
+2 new alternator and batt
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline AudiA8Quattro
Offline pauld_88
got the wrong alternator in the car try a new battery and the correct alternator either that or the RTX one has a fault ive worked with alot of RTX new units and they seem fine to me!
www.m25dubs.com
Golf Mk3 GTI 8v - sold
Audi a4 1.8t QUATTRO (B6)
Offline danny_p
alternator overchargeing.
don't matter what battery it is, all 6 cell wet lead acid batterys are the same voltage and no alternator desinged for said battery should overcharge it regardless of battery size
all the VW's have gone bar 1.
Offline Thebuzinezz
Thank you for the imput guys.
