Author Topic: dash light upgrades?  (Read 1177 times)
Offline Colin
« on: 04 January 2005, 14:19 »
Does anyone know what type of bulb and how many are fitted in a Mk2 GTI dash panel?
i want to try and upgrade to led's if i can, but need to know which bulbs?
Any ideas.
 :undecided:
ps, www.ultraleds.co.uk
for all your pimpy bulb requirements
Offline Colin
Re: dash light upgrades?
« Reply #1 on: 05 January 2005, 10:36 »
 :cry: the links not working, obviously i know the site so can you give me the description, cheers
« Reply #2 on: 05 January 2005, 12:19 »
Those wont fit very well, as you can see the lugs to hold the bulbs in place are directly over the contacts.  On a MK2 the lugs need to be offset to the lugs if you get me :(
You want these ones:
http://www.ultraleds.co.uk/product_info.php?cPath=44&products_id=302&osCsid=c60c8ecdeac22fed392ccfc0d12a6b21
But you have to modify the housings a little, theres a little lug which stops the bulb twisting far enough, you just cut this off and you're away :)
Make sure you test the cluster before you put the dash back together as LEDs only work 1 way round.
