Author Topic: throttle bodie clean :(  (Read 2477 times)
Offline matg340
« on: 13 July 2010, 23:45 »
Hey folks , i decided today i was gonna do a tb clean as shown in the maint thread ,
I have an 99 1.8t agu and tbh the tb was bloody filthy ,cleaned it up like new put it back together and noticed the tick over had crept up to about 1200
Now it seems to be getting worse when its warmed up,mine is cable operated too so am i right in thinking it shouldnt need realigning ?
Biggest concern atm is i should be going to R-tech on friday for a remapp and im presuming this could be a problem ?
Has anyone else got same engine and had similar problem or anyone got any suggestions ?
Any help is appreciated folks
preserve wildlife.......PICKLE A SQUIRREL !!!!!!!!!!!!
jamie16v
Re: throttle bodie clean :(
« Reply #1 on: 13 July 2010, 23:52 »
vacuum leak between manifold and throttle body?. cable adjustment?.
Offline james2
  • No scammers please.
« Reply #2 on: 14 July 2010, 00:07 »
the best way of cleaning it is removing the induction pipe get a friend to hold the throttle down and get a cloth with carb cleaner on and clean it out ...i would never take it apart as the problem your having.........get it to r-tech if you can they will help .........TOP BLOKES :drool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline vwprime
« Reply #3 on: 14 July 2010, 00:16 »
You will not have to do an alighment as the its cable.
Have you fixed the cable properly to the butterfly and also attached the pipe that atached on top ok? I know this might sound a stupid thing to say but some times these little thing are the corrs. :)
TRANSFORM, & ROLL OUT!
Offline matg340
« Reply #4 on: 14 July 2010, 06:22 »
Thanks for the replies fellas
Checked all the pipes after they seemed ok , first thought was maybe leaking between manifold and tb so i ordered a new gasket yesterday
hopefully get that this mornin ,
While im there ill check everythin over again for leaks , car is drivable just ticks over too high , read on here and elsewhere that sometimes
it just needs to settle back down and after a few miles it sorts itself out ?
Anyway ill put the new gasket on and let ya know but thanks again folks
Offline Lewisf1988-DUB
  • 1.8T AGU
« Reply #5 on: 14 July 2010, 10:15 »
Mine did exacty the same on my 2000 agu, takes a good few miles till it settles down. Just give it a good drive it should sort itself :)
Offline wratey
  • 2000 Mk4 GTI 1.8T
« Reply #6 on: 14 July 2010, 10:40 »
My AGU did this aswell, it should settle down. Also try disconnecting the battery, leaving it for an hour or two then reconnect, worked for me!
Offline Deano2711
  • 1992 VR6
« Reply #7 on: 14 July 2010, 11:31 »
Try disconnecting the power connector off the throttle body for about ten minutes. Then reconnect it and with the door open turn the ignition to position 2 and wait. You should hear a buzzing type of sound for about 10 seconds. When this has stopped start her up and see if that works. The throttle body will self adjust itself if you let it. Other than that just take it for a good long spin as advised by others on here Mate.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #8 on: 14 July 2010, 11:47 »
your throttle needs to adjust. after about 100 miles will be fine. Nothing to worry about.
Will be fine at R-Tech how it is, it'll probs sort itself before you get there, if not the lads will sort it out.
Offline richw911
« Reply #9 on: 14 July 2010, 18:13 »
+1  :wink:
