Author Topic: Oil Pressure/Temperature on filter and side of head  (Read 1336 times)
Offline warnesey333
Well I'm finally coming close to completing the rebuild of my mk2, but I just want to make sure that I have everything.
In total, there are 3 holes for oil switches to go in.
From what I understand, the side of the head is the blue(?) and uses a higher (1.5 - 1.8 i think) bar
Whereas the one on top of the filter housing uses a lower pressure?
If I were to replace all oil temp senders and pressure switches through GSF, what parts would I need through their website?
There seems to be an awful lot of pressure switches and I am confused as to which to get...
Cheers for the help
Jack
Re: Oil Pressure/Temperature on filter and side of head
« Reply #1 on: 14 July 2010, 09:08 »
if its an 8v:
large blue or brown, 0.3 bar pressure warning switch -> side of head
large white, 1.8 bar pressure warning switch -> filter housing
small white, oil temperature -> filter housing
if its a 16v:
large blue or brown, 0.3 bar pressure warning switch -> filter housing
small white, oil temperature -> back of head
small black, coolant temp -> side of head x3
Offline Horney
« Reply #3 on: 14 July 2010, 12:30 »
And don't buy GSF ones, they leak. Get gen VAG ones from a dealer or TPS.
Nick
jamrock
« Reply #4 on: 14 July 2010, 13:48 »
£30 each when i went to check last week.
nearly a ton for three sensors!!!  :angry:
how about ECP??
