Author Topic: Electric window :/  (Read 1157 times)
Offline 86 GTi
Electric window :/
« on: 13 July 2010, 15:28 »
Hey guys,
Just got my car back after a few months of it being in storage. I thought i'd go around the car and repair what ever, im having a little bit of bother with the left side electric window. It was siezed when i bought it so i took the door pannel off to see whats what, i checked the power going into the window motor and that was fine. So i wondered if the motor was seized, but the motor seemed to be working fine.
Which then brought the blame down to the window itself, for this i reffered to the Haynes for some directions of how to unstick it and it said i should undo the three bolts of the guide rail (which i did), i then gave it a wiggle around and then the window came loose. BUT then i made a schoolboy error (although i am 14  :embarassed:) and without attatching the guide rail tried the window again, it wouldn't go down but it went up past the motors limit so then i have no way of getting it down because theres so much tension on the motor. Or reattatching the guide rail.
 Is there anyway of releasing the tension on the motor? Or bringing the window down manually? Sorry if this isn't very clear but can't really explain it without showing people directly  :embarassed: Also for bad spelling but you'll get the jist  :drool:
Cheers Tom.
« Last Edit: 13 July 2010, 15:30 by 86 GTi »
Offline zedox
Re: Electric window :/
« Reply #1 on: 13 July 2010, 16:01 »
Funnily enough I had my passenger side motor out over the weekend (was squeeking like a b!tch)
Anyways, I couldn't see any obvious method of winding the window down manually.
I guess you could unbolt the whole mechanism and try and bring the window down with the mechanism still attached until you can unbolt the retaining clip (the long bar attached to the bottom of the window)
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 13 July 2010, 16:27 »
Take the whole regulator mechanism out. Undo the screws on the winding mechanism playe to expose the reel that the cables are wound around. Using a flat blade screwdriver carefully prise the reel upwards. One free manually unwind the cable so that the window holding bracket is now at the bottom position.  Then replace the spool and away you go.  Make sure the cable is properly seated in the groves of the spool.
Offline 86 GTi
« Reply #3 on: 13 July 2010, 16:48 »
Great cheers i'll give it a go  :wink:
