Author Topic: 16v clocks  (Read 1655 times)
jamrock
16v clocks
« on: 12 July 2010, 22:28 »
my GTI used to be an 8v.
what clocks do i need to get now as its a 16v, its an E reg so it has one plug clocks at the moment. how can i be sure they are 16v clocks when i am buying them??
Offline Neo Badness
  • Feet are for pedals
Re: 16v clocks
« Reply #1 on: 12 July 2010, 22:34 »
16v ones go up to 160mph :wink:
jamrock
Re: 16v clocks
« Reply #2 on: 13 July 2010, 00:16 »
cheers neo!!
i will have to try and track down some one plug 160mph ones.
Re: 16v clocks
« Reply #3 on: 13 July 2010, 10:16 »
if its an e reg it'll be 2 plug clocks. you dont need 16v clocks, 8v ones still work fine. 16v ones just have 160mph speedo and an 8k rev counter
jamrock
Re: 16v clocks
« Reply #4 on: 14 July 2010, 20:59 »
these clocks are the ones currently in the car. they look different from the ones on ebay
why do i have this selector?? it does not seem to do anything
thanks
Offline Neo Badness
Re: 16v clocks
« Reply #5 on: 14 July 2010, 23:02 »
Is it connected to the Flux Capacitor?
They do look odd though, normaly the mk2 petrol gauge is in the middle of the cluster, speedo on left and revs on right. Small rectangle of warning lights above fuel gauge and water temp above that. Your dials are wierd...  Must be rare :smiley:
Offline Reasty
  • Alpine white valver.
Re: 16v clocks
« Reply #6 on: 14 July 2010, 23:18 »
Looks to me as if u have the earlier 8v clocks with the mpg gauge where the water temp is on the later models,the switch probably switches between modes 1 and 2 on the digital display,one the later modles it's a slider switch  on the right hand stalk,do u have this? if not I'd say this is what it's for.
Re: 16v clocks
« Reply #7 on: 15 July 2010, 10:12 »
the 1/2 knob is for the mfa, switches between mode 1 and 2.
they look like early scirocco MK2 ones to me, afaik all the MK2s had the 1/2 switch on the stalk but i could be wrong on that.
