Author Topic: 17748 camshaft sensor, 5volts into sensor this right?  (Read 2484 times)
Offline brianpologti
hi all I am having a problem with my anni which is stopping me going to rtec to get a remap,
the history of the car was I brought it with a blown engine and turbo and partly stripped engine bay,
so fitted a new engine, hybrid turbo a few other bits,
the problem is it keeps going into limp mode,with code 17748 camshaft position sensor (g40/engine speed sensor (g28) incor correlation p1340-35-00
, so I though it must be camshaft sensor so tried on another car and that came up with it fault too, so replaced, (the replacement was then checked on another car and was working)
but stiill on this one it comes up with a fault, the plug was changed also to see if it was that, and i checked the wiring back to ecu and no breaks.
But I checked the feed into the camshaft sensor and it was 5 volts is this correct?
any idea's
could it be that the valve timing is out? as the engine has been stripped etc?
Re: 17748 camshaft sensor, 5volts into sensor this right?
« Reply #1 on: 12 July 2010, 20:16 »
think its a mechanical fault as I just checked my daily agu and that getting the same readings, I also swapped over the pick up ring to see if was that but still no that faults still there, has anyone got any links to a how to check camtiming etc, but if that was out wouldnt it run rough?
Offline Phil18t
« Reply #2 on: 12 July 2010, 20:28 »
yeh the ecu sends out a 5volt feed to the sensors and it switches the earths. have you done a continuity check from the connector back to the ecu? and from the connector to an earth to check if its rubbed thru anywhere? if all ok the timing could be a tooth out?
« Reply #3 on: 12 July 2010, 20:41 »
yer checked from ecu, and to earth, just looked on ross tec site, and they say timing belt or chain could be out, or faulty engine speed sensor ( so I just guess crackshaft)
but they are special notes, saying to check oil pressure as pump might be restricted,
or the wrong camshaft sensor fitted, single gap versus 4 gap, is there any different in visual look as to this?
think I try timing belt first unsure how to check chain. but I guess the camshaft pick up ring should be in the same position at tdc, as my agu, so I could copy that across and see,
or I might get a new camshaft sensor from vw then I know its 100% right for my engine,
« Reply #4 on: 16 July 2010, 15:59 »
Hopefully all sorted camtiming was a tooth out ,
Offline Giro
« Reply #5 on: 15 July 2012, 12:41 »
hi i think im getting the same problems as you had on your car
did the car still run ok but light a surge from the turbo like you had taken your foot off the pedel and back on. is that the car in limp mode?
i have replaced the cam sensor and still comes up with cam sensor fault
plz help
« Reply #6 on: 15 July 2012, 13:46 »
I had this fault alone with a few others , I found out in the end when the engine had been done it was a tooth out ,  It ran ok but just in limp but that could of been one of the other faults I had , 17705
« Last Edit: 15 July 2012, 13:48 by brianpologti »
Offline Giro
« Reply #7 on: 15 July 2012, 13:52 »
cheers for replying ill give the timing a check over
at least i will be able to tick that off the list of possable problems
