Author Topic: Painting engine block  (Read 2441 times)
Offline retromk2craig
  • Mk2 GTI And Mk3 GTI
« on: 12 July 2010, 13:34 »
I want to paint my block, and all bits attached to it like water pump, power steering etc
what is the best paint to use??the car is tornado red and want to match that? cheers
MK2 8V        MK4 4 MOTION
Offline dweb1989
Re: Painting engine block
« Reply #1 on: 12 July 2010, 13:49 »
Erm, red paint?  :grin:
Alot of people like hammerite.
I would go for some red high temperature paint.
Preferably enamel. Depends, how well you want to do the job though, red hammerite would be easiest way.
« Reply #2 on: 12 July 2010, 14:27 »
Hammerite ftw but I would leave all the bolt on parts in silver or black to be honest.
Offline emery1990
« Reply #3 on: 12 July 2010, 16:33 »
If do the main colour as black and have bits of red on it, maybe whole block black then power steering pump waterpump red etc. you need to keep the red block squeeky clean, with black you wouldnt need to worry as much. up to you though.
Ad said keep the bolts normal colour, or have them red on the block and black on the pumps etc, if going for the combo i said or just plain silver!¬
Offline Ben Lessani
« Reply #4 on: 12 July 2010, 18:37 »
Normal Hammerite is fine, but if you don't *thoroughly* clean the grease off the block, it will peel off within a year or two.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 12 July 2010, 19:51 »
Have it sprayed in 2K topcoat tornado red, doesn't get any better than that...
Thom
« Reply #6 on: 12 July 2010, 23:42 »
thanks for all your replys im just worried about the high temprature, i would love to paint it in tornado red. i got the paint. cheers
MK2 8V        MK4 4 MOTION
Offline danny_p
« Reply #7 on: 12 July 2010, 23:57 »
engine blocks don't exactly get hot.   most will never get hotter than 120   and if it gets to 150 your not worried about the paint
all the VW's have gone bar 1.
« Reply #8 on: 12 July 2010, 23:59 »
As above it will be fine.
« Reply #9 on: 13 July 2010, 12:00 »
ok brilliant so is there any parts i should paint in high temprature paint. cheers
MK2 8V        MK4 4 MOTION
