Author Topic: Fault Code P0299 - Boost Pressure Regulatio: Control Not Reached?  (Read 7066 times)
Offline johnford60
  • MK7 GTD 3 Door
Hi I have this fault code:
Where is the Charge Pressure Control Unit?
John
6683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
John
Offline joesgti
i think its the N75,
GTI MK5
Not the only GTI...........but the best! ; )
Offline johnford60
  • MK7 GTD 3 Door
I had the DV Valve changed  2-3 months ago. But the car feels under powered now with . I had the Fuel Pump Control Unit replaced as well, and that fault code is now sorted.
John
Offline dbcperformance
did you check your PCV?
-Berk
MK6 VW GTI APR STGIII
www.dbcperformance.com
Offline FamilyDub
PCV would be next on my hitlist to check, if I were you.
The PCV isn't that expensive (~£29), fairly simple to fit and it is a known weakness in the MKV... It solved almost identical issues you are have, that I was having earlier this year.
Even new spark plugs might help.
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline johnford60
  • MK7 GTD 3 Door
New Spark plugs Fitted :grin:
New PCV Friday  :grin:
Next? When you drive it, it feel hesitant!
John
Offline FamilyDub
Coil pack? Is is misfiring?
