Author Topic: Indicator problem  (Read 916 times)
Offline JDM82
Indicator problem
« on: 11 July 2010, 22:37 »
I have a indicator problem and i hope someone knows what it is.
I indicate, left or right it doesn't matter and nothing happens so I flick the lever back to the middle and down/up again and it works?
I press the hazard button and nothing so I de-press it and re press it and hey presto it works etc etc.
Also when the indicators are first applied my dash lights sometimes flicker. Also if I leave the indicator on say at a junction it'll tick tock away then kinda jump out of rhythm.
Any ideas? Ive just fitted some new hella rear clusters could I have loosened a wire or something?
GOLF GTi - The legendary hot hatch
Offline vwprime
Re: Indicator problem
« Reply #1 on: 11 July 2010, 23:13 »
Well all the indicator run off the hazerd swich so it might be that playing up.
TRANSFORM, & ROLL OUT!
Offline richw911
« Reply #2 on: 12 July 2010, 19:12 »
Indeed the relay is built into the hazard switch  :wink:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 12 July 2010, 19:35 »
sounds like a knackered relay it may be getting stuck so when you indiate a second time it may have become unstuck, failing that you may have charging issues but you would notice other electrical faults
