Author Topic: 312mm brake upgrade  (Read 1035 times)
Offline snap-on
312mm brake upgrade
« on: 11 July 2010, 20:36 »
just had rtech remap my aum and deffo need to upgrade the front brakes . i need new front discs and pads and can get the same oem parts for about a ton from tps and a tenner cheaper from the motor factors so just as well to get the oem ones .
as the standards are 288mm im thinking of getting the 312mm upgrade , but will they fit with the 17inch santa monica alloys ? a friend said they would as the v6 4motion runs the 312mm set up which a lot of them came with the santa monicas ?
i take it i only need the carriers to upgrade and not the calipers aswell ? and is it worth going the 312 setup or just stick with the 288 and get some red/green stuff pads instead ?
Offline bobbarley
  • I'm kind of a big deal...
Re: 312mm brake upgrade
« Reply #1 on: 11 July 2010, 20:40 »
They will indeed.
Yep that's right, as well as 312mm discs obviously.  You can even keep your old pads if you wanted to.
Definitely :afro:
Offline snap-on
« Reply #2 on: 11 July 2010, 20:42 »
sweet , will give tps a call in morning then to get a price on carriers  :smiley: bet they wont be cheap !
Offline bobbarley
« Reply #3 on: 11 July 2010, 20:50 »
Check out eBay.  I paid £100 for mine, which is probably a bit too much to be honest.
