Author Topic: r32 alloys spacer question....  (Read 770 times)
Offline paulturbo
« on: 11 July 2010, 12:10 »
at the end of the month i will be fitting my fk coilovers, with new top mounts,wishbones, and adjustable drop links. I am running r32 wheels at the moment and after reading a few other peoples post i am now wondering if i will need wheel spacers to stop the rim fouling on the strut of the coilover?is this the case and if so i was thinking 5mm spacer on each wheel at the front and 10mm on each at the rear? :undecided:
Offline vwfiend
Re: r32 alloys spacer question....
« Reply #1 on: 11 July 2010, 13:24 »
The rears won't catch with Fk's mate and you can get a rizla packet between the front adjuster and the tyre. If you do get a 5mm to go on the front just incase then don't get a universal pair as their almost Impossible to mount square and can slip
Offline paulturbo
« Reply #2 on: 11 July 2010, 13:42 »
ta very much.
