Author Topic: Car Won't Start!  (Read 2602 times)
Offline larry
Car Won't Start!
« on: 12 August 2003, 08:48 »
At the week-end i did an oil and filter change, rocker cover gasket change and changed the leads and plugs.
When i tried starting it up - it won't start.
I took the distributor cap off and cleaned the connections, made sure the little 'screw bit' ontop of the plugs was off.
The car turns over but will not start - PLEASE HELP I AM MISSING MY CAR
Offline richandhazel
Re:Car Won't Start!
« Reply #1 on: 12 August 2003, 09:36 »
Looking at what you have changed I would suggest that maybe you have the fitted the new leads in the wrong firing order?
Take the cap off and looking down on the distributer. Look for a mark/line on the distributer body. When the rotor arm lines up with this mark it is firing at number 1. Firing order, clockwise, is 1342.
Offline larry
Re:Car Won't Start!
« Reply #2 on: 12 August 2003, 10:29 »
cheers i will give it a go when i get home - if it is not the leads in the wrong place would do you else do think it could be?
« Last Edit: 12 August 2003, 11:12 by larry »
