Author Topic: How to remove the Central Locking pump from the drivers door?  (Read 1933 times)
Offline mboon
as above, got to replace mine as its leaking from the bottom.
How do I get the metel rod of that holds the door lock pin?
and I guess the rubber pipe just pulls off and on?
thanks
Mark
Part of the GTi 16v Flying Squad and the Special Forces //M Department
Offline The Mighty Elvi
  • I'm better than you today.
I took mine off and can't get it back on.  Cant work out what the top of the metal rod connects to.  Dont remember a rubber pipe as well.  Perhaps mine is missing.  Had a feel around the lock mech and there was some tape there. Mmm.
Can you post a pick of the unit and pipe, and the top of the metal rod - -is there a clip attached to it.
thanks
Offline warnesey333
Took mine off the other day, the metal rod on the pump seems to attach to the plastic sleeve which then slides over the lock mechanism!
Offline tony_ack
I swapped my driver's door a couple of weeks ago, and don't remember this being too difficult...
If i remember correctly there is a rod from the pump to a plastic clip that slides onto the lock mechanism. My clip may have been broken, so came off easily. Then there's another rod from the clip to the door lock pin (in fact the door lock pin screws onto the rod).
Vac pipe pulls off but needs a fair tug.
Then two screws and out.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Neo Badness
  • Feet are for pedals
TFE your sig made me laugh, that's spot on :grin:
There's a metal loop on the rod that attaches to the back of the door lock, it's spring loaded so can be a bit of a pita, but rest is pretty much as advised previously.
The more you fiddle the more it will become obvious how it comes apart.
