Author Topic: Door Trim Small Bumpered Model.  (Read 3585 times)
Offline X4MGS
  • VAG Parts SNOB!!!
« on: 10 July 2010, 16:41 »
Anyone know where you can get the Black-Red-Black GTI Trim that fits above the door rub trims...
I thought they were part of the trims but they are attached with Trim Tape and I need some more...
Thanks
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Door Trim Small Bumpered Model.
« Reply #1 on: 12 July 2010, 19:11 »
This is what I am looking for....
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 12 July 2010, 23:49 »
Anyone???
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 13 July 2010, 22:28 »
No One Have Any Help With This???  :sad:
Offline Neo Badness
  • Feet are for pedals
« Reply #4 on: 13 July 2010, 23:47 »
I'd say any semi decent factor should have something pretty similar, looks like sticky-back go faster stripes :smiley:
You got a pic of it on the car? Mine is small trimmed and I can't think what bit it would be.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 14 July 2010, 00:04 »
Neo...
Its the only bit on the outside of the door... It fits above the rubbing strip... Only GTI's have it...
It's a quality bit of kit with an alloy backing and trim tape....
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 14 July 2010, 00:13 »
Im thinking that, that trim is OEM, but not VW! Im sure I can remember fitting that stuff to something in the 90s, but for the life of me, I cant remember exactly what... but Im sure that it was fitted GT versions of something as a bumper trim..... I'll sleep on it :rolleyes:
As the pic shows, It should actually be black tape, with a printed red line, Why not get some 30mm matt black tape, and finish it with 10mm  matt red... Will look proper OE then :cool:
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 14 July 2010, 00:29 »
Cos it's fitted to 3 out of 4 doors and also on the wings... Just trying to get the proper OEM stuff...
I think it "MAY" be PN 357 853 949 but its listed as a seal and comes in 1520mm rolls, so I dont think its that - So ETKA says...
All Other Trim Parts are NLA and ETKA dont have part Numbers for 'em
So at a loss really!! :cry:
Offline Thom89
« Reply #8 on: 14 July 2010, 00:31 »
As said, NOT a VW part...
Check this thread out... http://www.golfgtiforum.co.uk/index.php?topic=159263.msg1468275#msg1468275
Thom
« Last Edit: 14 July 2010, 00:38 by thom89 »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 14 July 2010, 00:52 »
Thanks for the tip... If all else fails then maybe....
Searching Ebay.de to see what I can find... Other option is getting the Red trim off a small bumper and making that fit.
I have also seen a small all rubber trim 55mm but it don't join up at the arches and looks silly - I would still have the holes to sort then...
